its fine other than the fact it takes a long time to balance that one cell - when its not used daily -
i am curious how bad would it be to just leave it and use this way - what happens if one cell does go bad discharges much faster than the rest of the pack - if i dont do nothing to this - what happens to the rest of the pack when in use ?
Burgerman wrote: And I dont know why I bothered to write all this as you will read one line.
Burgerman wrote:Cell 8 has bad connection somewhere. Or is very high impednce.
Cel 5 is far from charged for whatever reason. (self discharge?)
Are your balance wires CRIMPED?
Thaat will definitely do it.
Burgerman wrote:Are your balance wires CRIMPED?
Burgerman wrote:Then there is likely many of your problems. I said dont crimp for very good reason.
We are balancing to a mV.
Do you know what voltage you get when you join copper wires to a brass or zink coated connector? You get 1.1V or if you like 1100mV... Because that forms a battery once it oxydises a bit or the humidity gets into it. Crimping is no use. http://hyperphysics.phy-astr.gsu.edu/hb ... trode.html
How is the charger supposed to display a proper cell voltage or balance a cell, to within .1mV when you are putting little batteries at avery crimp! That can produce as muct as 1100mV depending on damp, oxidation, etc.
Burgerman wrote:Not watching yourself. Quite.
There are millions of BMS equipped packs that are suffering all kinds of issues. But the user has no idea. Until one day they stop very unexpectedly.
Users browsing this forum: No registered users and 25 guests
