REPARACIÓN SILLAS wrote:Hello, we are also here with several VSI joysticks and a New VSI with all the LEDs blinking 7 and 8 times. We know that there is not much to do in these cases except the replacement of the microprocessor. There are repair services that do it, we are trying it in Argentina, we will see how it goes. We already have the programmer almost ready if we find the solution we will share it.
We noticed that in the event of a sudden variation in charging or discharging, either due to home voltage/charger problems or faulty cables or joystick plate for safety reasons, they fail.
expresso wrote:Normally seven flashes means it is locked up. To reset is simple., just push the button on the control head (where the joystick is), to turn it off. (That is if it is not already off). Then push the button to turn it on, and when the flashing starts push the horn button twice. That should unlock it. Some people think of it as a reset. That should solve the problem. If it does not check your cables and make sure they are connected. These are the cables that run from the control head down to the base. If your not plugged in and your not in neutral, (check your levers), then you should be good to go. If not it may be your batteries.
woodygb wrote:I should have said use the PC Mobility Programmer on the controller and run "Checksum correction" etc etc .
Possible Joystick Trip
A joystick trip is indicated.
Make sure that the joystick is in the center position before switching on the VSI.
Users browsing this forum: No registered users and 346 guests
