what do you think about continental globe batteries ?
Postby yeshelp » 29 Nov 2021, 19:52
hi
i might receive help to buy batteries gel gr24.
At the moment it seems like only continental globe brand are available.
maybe i could find a seller that sells MK batteries but before i need to know how do they compare...
Anyone knows the brand continental globe? are they the same quality as MK or like to avoid? i look for long life batterie as many years as possible
thank you !
yeshelp
Re: what do you think about continental globe batteries ?
Postby daveonwheels » 29 Nov 2021, 19:59
avoid them at all costs. they are not for wheelchairs.buy MK's!
daveonwheels
Postby martin007 » 29 Nov 2021, 20:34
Postby daveonwheels » 30 Nov 2021, 02:52
they make a 73ah gel battery with unknown characteristics. probably grp24. probably unsuitable internal resistance [too high]. stay away. buy MK.
daveonwheels
Postby yeshelp » 01 Dec 2021, 23:24
hi
there is a scarcity in batteries . I cannot find mk batteries close.
if i convince the donator in the value of giving a little more money for me to buy batteries new, wich do you think is the better and how does it compare to mk gel batteries?
looks like those 2 are available close to me
odyssey
ODP-AGM24F BATT AGM GR24 12V 725CCA 155RC
10-101-15120
Prix détail / Retail Price
CA $509.95
https://www.batteriesexpert.com/en/pare ... 5cca-155rc
enerwatt
GEL12-75 GEL BATT 12V 75A HR(GR.24)
10-121-15009
Deep Cycle batteries in the sealed category with Gel offering a far superior charging capacity in comparison to regular AGM, this is due to the volume of electrolyte which offers you more charge/discharge cycles than acid batteries.
CA $419.95
https://www.batteriesexpert.com/en/batt ... 75a-hrgr24
yeshelp
Postby Burgerman » 02 Dec 2021, 01:10
Well the odyssey is a small 63Ah battery in a case thats too big to fit, and the gel battery as a pretty high internal resistance so may feel "run down" when fully charged in comparison to the MK gel (4mOhm) by a little. And no cycle life info available. But its the only one that fits. http://worldbatteries.net/PDFs/1012115009spec.pdf
Postby sacharlie » 02 Dec 2021, 01:31
You may find the Deka Dominator Gel. East Penn battery makes both Deka and MK. Identical specs on both batteries. I use Deka.
sacharlie
Users browsing this forum: No registered users and 62 guests
