Strange thing has been happening
i had a Circuit Breaker 80A those cheap inline for Audio stuff really - i was using it on my load bump so i can push the button to stop it easier -
while using it - it has been tripping - the load dump is only pulling 35A it shouldnt trip - so i figure ok its a cheap thing i paid 12 dollars
so i ordered a different kind on amazon - 60A - i figured it should be enough either way - i am not pulling more than 35A even 40A at the very most but the watt meter shows 34A to 36A at times so even a 60A breaker should not trip - but it did
i did a return - i reordered a Bussman this time 120A - i figure i can use it for a chair also in case i ever needed -
https://www.amazon.com/gp/product/B01G5 ... UTF8&psc=1
this one below 60A is the one i had and returning it tomorrow
https://www.amazon.com/gp/product/B09CY ... UTF8&psc=1
is there anything wrong that i am missing here - it should have been fine -
I have a 100A one on my Chair - first one i did with the 105ah pack - 6 years and working fine - never tripped - as it shouldnt - chair dosnt pull that much - if it does very short - remember the stock fuses on the chairs are 80A with the lead batteries
is there anything wrong with this that i dont see in the specs etc,
i though maybe i connected it in reverse - so i turned it around and reconnected the wiring - same thing - it worked both ways and tripped both ways
