I'm less inclined to credit the complex programming options in wheelchair controllers unless your condition requires filtering the joystick input due to poor hand function.
ouaburst wrote:OK, this seems to be overwhelming project.
My goal is to built a cart with powerful wheel.
My inspiration comes from this Youtube page: https://www.youtube.com/channel/UCbazCk7W64I_IwAJG1XL7Pg/videos
Can anyone guess what type of wheel motor does they use?
slomobile wrote:ouaburst wrote:OK, this seems to be overwhelming project.
https://burro.ai/robots/ motors are listed as 5 horsepower. That is equivalent to about 3,600Watts. That might be the total for all 4 wheels 3600/4 = 900W per wheel.
There are a number of ways to get powerful motor/gearbox combos.
Here is one source http://www.teamwhyachi.com/rightanglegearboxes.html these are gearboxes.
The motors they use are here https://www.ampflow.com/motors/highPerformance/
A very reliable controller is https://ampflow.com/controllers/vex/
You might be able to get by just fine with the motors and controllers you already purchased, just with smaller loads. Be sure to keep the wheels as close as you can front to back to minimize turning losses. Building that bot will get you experience and help you decide if you really want to spend more for a more powerful one. The software and high level control costs the same regardless of how powerful the motors are. So use your little motors since you have them.
Looking at Lenny's script which BM posted, it looks a lot like Visual Basic but can probably be translated and adapted to C++ for Arduino. Lots of the algorithms in it are similar to what I used on Arduino robots. I never bothered with IR compensation because I just added an encoder if I needed to control velocity precisely. You can choose what works best for you.
Profile WC_CAN xxxx.xml includes settings for analog joystick
and speed pot connections (AIN1, AIN2 and AIN3) for testing
non-CANbus scripts.
An analog-only version of the script is NOT included in this release and
users are urged to move to the more robust CAN system.
Users browsing this forum: DrewDigital, woodygb and 42 guests
