steves1977uk wrote:On my chair, the female D-Sub connects straight to the cells and is housed in a waterproof cover on the outside of the battery box. No worries of any wires rubbing or touching. A simple solution like that would be all you need expresso. No need to overthink things.
LROBBINS wrote:After multiple cases of pinched wires in moving machinery (and lots of magic smoke) I have taken to using a dab of my favorite - Goop a.k.a. E6000 - to tack wires down so they stay in place.
For my last bit of chair wiring I found an Aliexpress seller for fiberglass-covered, silicone-insulated wire. Silicone insulation is very flexible and heat resistant, but easily cut, so I'd avoided it before this. With the fiberglass it seems much less damage prone. https://www.aliexpress.com/item/4001211751252.html?gatewayAdapt=glo2ita&spm=a2g0o.order_list.0.0.21ef36961rcZGP Though this page doesn't show it, they can also supply 10mm^2 and others.
Burgerman wrote:I use velcro / velcro mounings, and cable ties.
i see cheeks in the future
Burgerman wrote:I thought you did.
As close to the batt as possible is best but it will be OK as long as you understand its purpose. It exists to protect the battery cables. So if you manage to scrape the insulation off between the battery and the fuse it cant help you.
Burgerman wrote:As close to the batt as possible is best. It exists to protect the battery cables. So if you manage to scrape the insulation off between the battery and the fuse it cant help you.
Burgerman wrote:It is in the main pos 24v line on many chairs. It can go between cells, between batts, or even in the neg wire. Some of my chairs dont actually have one. Never got around to it!
Burgerman wrote:I dont. I should. 40A ideally with the PL8 and silicone 12guage.
if the ADD ON cable would short - would the fuse on my ADD ON protect or the bounder breaker protect etc, ?
the ADD ON pack has a fuse on the Pos. near the battery side -
that same wire with the fuse on the ADD ON cable gets connected to the ADD ON Cable and down to the bounder pack -
that cable from the ADD ON to the bounder has no fuse on it - the end connected to the ADD ON cable XT90 has a fuse - just the cable from the ADD ON down to the bounder does not - if i were to remove the ADD ON cable that connects both - that one is not fused -
if it were to short for some reason - the ADD ON pack with the fuse would cut power ?
what would the bounder pack do in that case - keep working or can trip the breaker on the bounder also ?
let me find a pic to explain - this whole thing is making me think things over with fuses on the charge cables also - never though about that - i never heard anything here about it -
Users browsing this forum: acid_coke, F3Head, Smark67 and 49 guests
