steves1977uk wrote:Always good to double check things expresso.
fishinjunky wrote:Does your cable go from pl8 -> subd -> xt90 -> battery ring terminals?
Burgerman wrote:SubD always that way - the correct way - i posted tons of pictures - same with the XT 90 was always used as part of my charging cable - Subd - one end - XT 90 the other end -
OK... SubD chair end of cable. And the other end goes to the PL8 which doesent have any XT90... So where are you pluging that into???
Its very hard to get a simple answer. You seem to have gone into full on panic mode, developed verbal diareah and typed a 30 page book of confusion. You keep on repeating yourself but never explaining or answering questions.
So take a deep breath and gather what you want to say first before typing half a dozen posts. Things are usually something simple. And then once you gathered your thoughts explain it clearly using logic. Because I still have no idea where on earth you can plug in (or or could need) anything other that the 4mm safe bannana connectors, along with the PL8s 9 pin balance connector at the charger end.
Why would there be an XT90??? What is that for? Its not in the charge cable, or on the chair???
ON the charger end - there is NO XT90 - never was -
i posted many many pictures - from the 7 years - you can see i use a XT 90 from the start on the charge cable Female end that goes on the chair - -
one end is the female SubD - the other end power lines are XT90 - that XT 90 gets plugged into the pack for charging only - the main lines go to the SB50 from pack to the chair
this simple enough - do you see it now how the XT 90 is in the picture here :thumbup
you have two 12awg cables and balance wires inside the SudD ?
soldered to the connector with the Holes
thats one end of the charge cable isnt it ?
whats on the other end ?
and you were to the one to tell me about the XT90 to begin with
Burgerman wrote:and you were to the one to tell me about the XT90 to begin with
Yes to connect an addon...
Burgerman wrote:One ring or two? Will make around as much difference as your additional XT90...
And a bent wire is fine the elctricity doesent care about corners.
Can the strands inside the cable be broken if the outershell is not - is that even possible ?
Burgerman wrote:Think about the stock chairs. Theres no fancy sleeving or anything they just rout the cables where they wont be trapped or damaged. You are overthinking everything.
Users browsing this forum: woodygb and 50 guests
