All compltely different shaft diamter, hub, taper, offset etc but easy enough to sort out. On that page you are looking at I show two methods already...
The welded adapors were for hegar. The machined ones were fo the temporary cheap steel quad bike rims while construction/testing. Although you might be able to mod those. No drawings I work on the metal. There MAY be a .zip in the page though.
For cheap steel quad bike rims alloy adaptors.
For the 6 bolt hegar rims... made on lath ready to weld to the hub (left).
TIG Welded on to hubs... By college guy. I have no welding equip here.
Fitted modded hub to motor. Sprayed mat black with rattle can. Dont like rust.
Fitted Wheel.
