Curtiss 1208-C controller
Postby mrgus2u » 27 Jun 2022, 06:03
Any info on programming this one is appreciated.
Can it be programmed with the 1314 software? Or do i need the hand programmer? Is there a Curtiss controller, but microprocessor based, that can replace it without changing the harness?
mrgus2u
Re: Curtiss 1208-C controller
Postby woodygb » 27 Jun 2022, 10:46
As far as I am aware the 1208 is not programmable.
http://liftpartsrus.com/Controls-all/1208%20Manual.pdf
Replacing it with a another make / model will entail changing the part of the wiring loom that plugs into the controller.
The Curtis 1228 or a Penny & Giles ( Curtiss Wright ) S-Drive are both suitable replacements.
https://cdn.curtisinstruments.com/produ ... eet_en.pdf
https://davilot2.ccvshop.nl/Files/10/26 ... manual.pdf
Postby woodygb » 27 Jun 2022, 15:32
You can easily modify a 24pin ATX plug to fit either of the above mentioned controllers by cutting off just one end ....you will of course need to wire this in place of the 1208 plug.
Postby mrgus2u » 28 Jun 2022, 04:20
Thanks Woody. You are the Oracle of motor control. :thumbup:
mrgus2u
Postby martin007 » 28 Jun 2022, 23:08
woodygb wrote:As far as I am aware the 1208 is not programmable.
Where do you get these manuals from?
I'm interested in all that exist.
I want to form a library.
Postby woodygb » 28 Jun 2022, 23:13
....I simply search the web.
Postby martin007 » 28 Jun 2022, 23:16
On Google?
Postby woodygb » 28 Jun 2022, 23:18
Yes ..Google.
Formatting the search correctly helps e.g.
search pgdt s-drive pdf
https://www.google.co.uk/search?q=pgdt+ ... nt=gws-wiz
or pgdt s-drive manual pdf
Postby martin007 » 28 Jun 2022, 23:19
OK.
Postby woodygb » 28 Jun 2022, 23:28
pride q-logic manual pdf
https://www.google.co.uk/search?q=pride ... nt=gws-wiz
enAble50 manual pdf ... ( A Curtis product often relabeled )
https://www.google.co.uk/search?q=enAbl ... nt=gws-wiz
enAble40 manual pdf ... ( A Curtis product often relabeled )
Postby FelipeOliveira » 03 Jul 2022, 09:12
mrgus2u wrote:Any info on programming this one is appreciated.
what exactly do you need? any specific information? or everything? what model of scooter is the PMC 1208c installed?
FelipeOliveira
Users browsing this forum: SweetBearCub and 6 guests
