wheelchairer wrote:it's a bit too much for me ability and pricewise.I have the coolice, but I'mm always having problems with the carers plugging it in properly and it's just blue one of the sections for the 2nd time.
Martin, this ridiculous power supply was started ALL because of you , itsn't itmartin007 wrote:Do you think Shirley's ZXD is expensive?
It is expensive. It soars up from $1,600 to $2.200 HKD . Shipping fee, adding Anderson SB50, labour , all added up.
Well I meant to secure the to plugs in the back of the power supply so they can't come out.steves1977uk wrote:The Coolice PSU's are ok as long as they're plugged in correctly. By the PSU keep blowing, I assume the carer's are only plugging in one IEC plug which causes one of the PSU's to be overloaded and start puffing out black smoke? That's happened to me but luckily noticed it and stopped the PL8 immediately.
Chargers, I’ve not been in the forum lately but what brand chargers are people trying now?
We’ve got two choices now I think, iCharger which has the long history and established brand name behind it like Revolectrix did and to be fair these two were THE brands to have. Then we have the cheaper, but equally capable ISDT now which while they might not have the overall quality of an iCharger certain perform well and you get a lot for your money.
So in keeping with following the PL8’s 8s cell count capability we have these chargers to look at;
iCharger X8; https://www.aliexpress.com/item/1005001 ... 7512%21sea
Nice charger, but not talked about so much lately with ISDT bringing the same power levels at a cheaper price, so now ISDT’s offerings;
ISDT Q8 500 watts and up to 8s; https://www.hobbyrc.co.uk/isdt-q8-500w-dc-charger
Newer Air8 version; https://www.amazon.co.uk/ISDT-Battery-C ... C40&sr=8-1
Or the more powerful Q8 MAX version with 1000 watts; https://www.hobbyrc.co.uk/isdt-q8-max-1000w-dc-charger
ISDT also do some chargers which are both DC via power supply and AC via cable all-in-one chargers;
ISDT K4; https://www.hobbyrc.co.uk/isdt-k4-600w- ... dc-charger I have heard this isn’t very accurate recently with a customer having a PSU from me to go back to iCharger.
ISDT X16; https://www.aliexpress.com/item/1005003 ... 4715%21sea mega money sadly.
Neither of these two DC/AC chargers I have had experience of, but I wanted to show you them anyway. Mind you in order to make any real power they do so from an external power supply anyway, so it negates any advantage over one of my PSU’s and a charger built into a case.
Personally I think I would go with an ISDT Q8/Air8 (500 watt) or the Q8 MAX (1000 watt) built into the smallest case we can with your power supply underneath it, so you have a mobile charging solution. I could also add in a power output point on the deck, or side of the case itself, so if you wanted to use the PL8 you can do by simply using the case as the power supply for it.
But then when going away, use the ISDT inside the case.
It’s all very modular to so should a PSU fail, it would be very easy again to swap it out to minimise down time for you which is a priority.
To give you an idea of case size, I am fitting two Q8 inside this case with the PSU’s you have side by side under them;
https://www.waterproof-cases.co.uk/prod ... ase-max300
For the more powerful Q8 MAX I might have to create a raised deck design as it’s a taller charger from memory, but I should be able to use this case still, or worst case scenario the next size up; https://www.waterproof-cases.co.uk/prod ... h160-black
Some ideas for you to consider mate and doing things this way we keep your PL8 in stock trim without messing with it.
So on my wheelchair I have the PL 8 balance cable which if you remember has a peculiar plug that is only specific to the PL 8. So would we be able to adapt the ISDT Q8 Max 1000W DC Charger to using a PL 8 balance cable I can provide you so the balance cable I have now on my wheelchair can plug into this charger? Also, Is there software so I can;
1 control the operation presets and everything on the Q8 Max charger
2 I can start the operation of the charger from the PC?
can you explain that a bit further please. You are saying it is better charging at a low voltage whenever possible?martin007 wrote:shirley_hkg wrote:
I keep seeing it cheap.
By regulating the voltage I extend the life of the batteries...
The power supply pays for itself.
Users browsing this forum: DrewDigital, woodygb and 57 guests
