Ask rover. Theres nothing really to "service" on a powerchair.
All you can do is look it over for stuff that should never have come loose. Or cables that shoud never have been damaged if routed correctly in the first place. And look at tyres, check by spinning and rattling around looking for bearing free play.
Really thats it.
So paying someone to do the blindingly obvious isnt needed unless you cant do that.
Nobody has looked at any of my chairs for 20 years. Because its faster (isnstantanious!) to look at your own chairs as you go day to day. And faster to repair your own too. Provided that you have a dealer or manufacturer that can and will post you the parts. That normally takes 3 or 4 days. Can be longer if they need to order something out of stock. Thats never happened to me so far. But it can do. As long as you are organised and have a spare chair (or two spares) as you really really should then no problem. YOU are likely to do a better job configuring, programming and fault finding than the dealer/tech is. And you wont need to send it away in a van to a place where they can be completely bewildered without you watching!
E.g. TODAY (yesterday now its late!) my chair cut out 3 times as I accelerated very suddenly and stopped dead like you ran into a wall. Thats not good for the motors or gearboxes and I almost fell out! After the 3rd time I saw the pattern. The controller did not turn off (as happens if its a bad connection to the battery or battery loom normally). It left me a error message LOW BATTERY on screen. And wouldnt move unless restarted. This was not a low battery. There was 1 light out. It measured 25.7V. So what could this be? Well if the controller sees less than 16V for an instant (as I accelerate hard from zero with my 90% acceleration setting) it "trips" as it sees the battery voltage collapse as the battery current hits well over 130 Amps or greater. Because cheap batteries are crap. Too high resistance, and so as soon as its not FULLY charged any longer it cant cope under load any more and as you ccelerate battery voltage spikes below 16V limit. And bang. We stop dead! This is EXACTLY why I buy either Odyssey (wont fit the salsa) or lithium. Cheap backup battery chinesium batteries just dont cut it.
Ask your self. Would the tech have been able to figure that out? Or would he be ordering new looms, controllers, power modules, bus cables, etc? I know the answer to that. And when he was done £££££$$$$$ it would do it again all over again when the battery was no longer full. So its usually better to fault fing YOURSELF if you have half a brain and me or rover or a few others here like lenny/woody etc.
So now skint (air conditioner) I will either have to get another tempory set of lead batts
, or fit lithium. Which will now need to wait a couple of months... £££
