As for DYNAMIC load compensation settings, then it isnt needed if the chair is programmed properly anyway. And it also MUST still be mOhm progrmmed. Its just that the chair decides to increase it or decrease it over a very narrow range automatically so you dont have to. But it might not like my choice! And keep lowering it... Personally I find all chairs are set a little too low here. Because safety and variation of motors etc. So you should be FINE TUNING your own chair anyway... So thats also nonsense. Its mostly marketing nonsense. Probably prevents the ignorant "techs" setting it too high or low as it can "correct" what you did.
I can program an r-net chair to be MUCH more accurate, repeatable, and responsive than any of their stock chairs. Including deceleration, responsiveness, motor load compensation settings etc. Its not difficult! They keep on making "fixes" like this DYNAMIC load compensation to try to fix something that is caused by stupid programming and bad control pod positioning and technique. And it just doesent...
