Better have 2 pins to share a 40A load each way .
Burgerman wrote:I think you have most of the useful ones, except those EC5 ones, that I throw away. Those always melt or make bad connections.
I also suggest you get a couple of these with different multi connector ends. https://www.rc-hobbies.co.uk/shop/spare ... connector/
Lots!
https://www.google.com/search?q=multi+c ... irefox-b-d
So you can connect almost anything to charge it.
And balance too, a 2 to 8s balance board. I use these a lot. Depends what you are charging. These are not for chairs. But I charge many things.
https://www.ebay.co.uk/itm/185212604064
Burgerman wrote:Yes a hobby that teaches you everything! Although less today than in the past. But fun and a huge subject and never ending in complexity and cost!
I stayed on my bed today. Red mark
But my brain thinks I am looking out of my blue Land Rover Defender around half a mile away from my house. These HD DJI Digital goggles look so good that you forget where you really are. I am looking around my neigbours yard and confusing the dog. I nearly crapped myself when I felt a tap on the shoulder. My carer turned up, and touched me... I thought someone at the bottom of the street was in my Defender with me... Very confused for a second. I forgot I was on my bed at home.
Look carefully, its on the shelf here!
Its a "rock crawler" with 4x4 and low gearing. Tons of control and slow. It has a high quality camera inside and behind the windscreen. And long range RC with the FPV system etc.
Burgerman wrote:The ones that keep appearing are usually not pressure, or not ONLY pressure but shear forces (on bed or through not enough base dump deat angle, and through heat, sweat, and a candida infection that just looks like a red area. A little of two or more of these things. Best bet is to stay cool, (one reason I just ordered Air Conditioning for my room £££ AND because it also DEHUMIDIFIES and you stay very dry.). And repeatedly wash the whole area! With medicated soap. At least a few times daily. And mine at least go away again.
I dont use mine for rock crawling. More reconoitering the area. Spying... I have a 2W, 915mhz RC link. Gets around 30 to 50 miles theoretical airborn range. But easily a mile or more at ground level around buildings and cars. Same with the video link. Wide band, 1.2 watts, super high quality link. Looks as good as HD TV. It allows me to go anywhere in the nearby area and never loose video or control range. It does worry me that someone may steal it! With me inside.
greybeard wrote:Yeah, but less irritation factor.
But I do a lot of brief standing transfers where accidentally dropping trousers increases in probability.
Users browsing this forum: acid_coke, Jay_x, martin007, mentado020477, woodygb and 90 guests
