Almost all chargers claim to charge AGM and Gel. They seem to think its all the same thing...
But its not.
Well they WILL charge gel, but they will have a short lifespan.
Because anything that is intended for wet/agm/general lead acid will charge at 14.4 to 14.7V approx. And that will give you half the lifespan. And worse, they never tell us at what point the charger stops charging.
It should do that after 8 hours, or 1000th of the battery Ah in mA. So a 70Ah battery would be 70 to 140mA termination of CV voltage. THEN drop to a lower 13.5V (per battery, so double this)
But theres never any info. And they normally stop charging way too soon after say 4 to 5 hours. So on top of the over voltage we gat undercharging. Which again shortens lifespan by allowing sulfation to build fast. Instead of returning the sulfates back to the electrolyte.
So this is why its probably a bad idea.
And this comment in the feedback reinorces this:
Nicely Finished Charger
Very Nicely Made unit.
I would expect it to last
Good clear LCD Display.
Powerful Charges quickly and settles down to float mode quickly.
Well it SHOULDNT!
