by Burgerman » 07 Jun 2023, 09:50
Which, means the size of that "resistor" (the batteries own resistance) determines the actual current the battery can produce and the amount that the voltage drops at a given current (load) or given charge rate. Even ignoring the chemical "surface charge" changes.
It is also why when charging some power is wasted as heat, and the real battery voltage is less than we measure while charging. And the reason that the battery isnt charged as soon as it reaches the set voltage, and why we have a CV stage that takes a further 8 hours. Because while theres still some current flowing, the real battery voltage is less than we measure at the terminals or charger. And why we have to wait till current falls (very very slowly) to almost zero. Or around 1/500th to 1/1000th of the Ah capacity.
