by Burgerman » 15 Jun 2023, 20:57
The power module has the ability to sense heat caused by high MOTOR currents, and then to protect itself the power module reduces torque (Amps) allowed while it cools. So it rolls back torque directly.
What causes heat?
Resistance in the power stage mosfets. And high average currents.
What causes rollback and low or no power? Software trying to stop the mosfets from going up in smoke...
The power module has no idea of the actual temperature of a motor.
You can help prevent this thermal rollback by:
Fitting new motors. Old tired ones suck up more Amps and power for any given load/speed as efficiency falls over lifespan. Weaker magnets, dirty or burned commutator, wear in gearbox etc.
Losing some weight. Seriously. Weight and load (and so heat) are in direct proportion to each other.
Dont choose 8mph motors. They suck more amps, by around 25% at EVERY speed, and every load. Thats is all ending up as heat in the power module and motors. It also causes faster battery fade and higher peukert, and so quite severely increases heat and decreases range and battery lifespan.
Dont use in warm weather. You are halway there to the heat problem before you start.
Dont use fat low pressure tyres. Also "flat free" foam filled tyres cause high loading.
Hills. Hills murder motors, overheat controller power modules, wiring and batteries.
And a tiny fraction of 2 or 3 of these things above all conspire against the stock chairs and helt help this heat problem.
