Burgerman wrote:I would check on mine but I now have 1 profile.
And use the speed flag switch to go from too slow to catch cold, yawn, to wheelies and full speed in 5 steps. For the life of me I cant find any sensible use for more profiles. And you can run up and down these whole driving with one finger.
Added... My memory seems to remember this from somewhere!
Some joysticks do not allow button mapping, depending on manufacturer, power module firmware or joystck firmware from my failing memory. All my own sunrise setups do.
rover220 wrote:Momentary screens enabled?
I've got 1 profile on a chair which is fine if you remember to turn it down when someone else moves it or it destroys anything in its tracks.
It turns left and right too severely for indoor use anyway but is great outdoors. I prefer an ''empty' profile when others are around to move them and an indoor profile that isn't as sharp for manoeuvres where busy and tighter. Speed isn't an issue, sharpness is and I don't want to dull down my outdoor profile as it's pulled me out of a few situations in the woods over the years that my indoor profile wouldn't do.
Burgerman wrote:I dont see why that is any different?
If the chair is left on "fast" in either case the result is the same. The only difference is which button you have to press to do so.
But both ways would seem to work regardless.
Burgerman wrote:If the chair is left on fast on your ONLY profile if you forget then you should have left it on slow (on 1) instead.
If the chair is left on fast and you forget to change to a new slower profile (that is your "indoor" one) it will be just the same as above.
Theres theres no difference at all? A single button press either way makes it slow and exactly the same indoors?
Unless I am missing something.
But do it your way if you can get it to work. But my way means you dont have to fix your profile button problem.
Burgerman wrote:What happens if you swap joysticks between chairs?
Users browsing this forum: Burgerman, daveonwheels, Jay_x, Qvickster and 59 guests
