wes4dbt wrote:almost three years old but well taken care of. If I remember right, you go from the negative on one battery to the positive on the other, right??
martin007 wrote:wes4dbt wrote:almost three years old but well taken care of. If I remember right, you go from the negative on one battery to the positive on the other, right??
The batteries are plugged in series.
Burgerman wrote:Fully charged around 13V each.
Discharged near flat around 11.5v. Each.
Burgerman wrote:Do you mean power module?
How do you program it? No OEM access? Or do you? I ask because in order to set correct motor compensation, or even to make it steer properly you must!
Burgerman wrote:If it has 2 parts, power module and joystick, then the power module is where all the programming lives on PG stuff.
Burgerman wrote:Yes. Thanks! Will go towards hosting!
Users browsing this forum: woodygb and 35 guests
