2021 Permobil M3 Backup project chair joystick questions. My chair has recline/tilt/legrest and no seat elevator lift capability. However, only the tilt and legrest functions work. When I look at the joystick buttons mounted behind the joystick, only two of seating icons, tilt and legrest are lit green? When I go into the joystick mode and see the image of the chair seat on joystick which is yellow, only two functions tilt and leg rest light up yellow? Why no recline function is lit?
Why would the recline function not be lit yellow when I toggle through the functions by pressing the joystick to the right or left? I know the chair has the capability it worked before with a different joystick. I'm assuming it's a programming issue because there's no errors displayed on the joystick to indicate a problem in the joystick works perfectly. I did notice there looks like there's three programed functions M1, M2, M3 also in the joystick menu.
How do I figure out what the chair seating Memory functions will do? Do you think it's a programming issue or perhaps a loose wire or something else which doesn't let the recline function work? I don't think anything is broken because there are no messages or errors in the joystick and everything else works properly.
How do I load a factory default all seating functions profile? i.e. the one I came with from the factory? Note: I did put in alternative ICS switchbox for headrest switches.
F3HEAD
