Magic!
They finally FIXED the Magic Mobility 4x4 steering! Now you can get a 4x4 off road scooter that actually drives properly judging by the vids. It uses front steer, servo controlled.
Programing will be a nightmare as it will be using the same setup as the myra/permobil servo control system.
But at least it steers the correct end and so finally if someone wants an off road 4x4 capable scooter with joystick steer control there is one I would actually take a look at!
Might even buy one. Great for photography or my grass airfield.
4 provisos.
1. It will murder batteries (esp off road). With 4 soft fat tyres and a lot of mass. So a 230Ah or bigger lithium setup (now costs the same as ONE lead brick so no big deal) is essential to be any real use. And saves weight too! And this thing is heavy.
2. And will be short on torque due to current limit of 110A per (linked) channel. So will NEED a cooling fan on the power module (trivial to do) to stand a chance of actual serious use.
3. It isnt a wheelchair, no tank steer, wont ever be anything but an outdoor device for getting around & steering like a small car. So its a scooter!
4. Servo controlled stuff is horrible to steer at speed as its servos are slower than my fingers and depending how much "lock" you applied and how far it needs to go to get straight again it adds variable response time. So to me at least feels like steering a RC car with 1970s very slow servos... Looking at the vids. But still WAY WAY better than that previous flopping side to side nonsense!!!
https://www.sunrisemedical.com/power-wh ... errain/xt4
4 provisos.
