Burgerman wrote:Noise doesent sound very serious.
Could be motor brushes running against commutator, rubber cush drive, motor bearing noise, or the brake dragging very slightly.
Burgerman wrote:Those things are wire joiners...
That metal tube is just a "roll pin" used to lift the brake off.
martin007 wrote:A question Pierro.
What material is your living room floor made of?
Burgerman wrote:You live in spain. Where ceramics are common and very hard wearing. They just dont wear out!
ex-Gooserider wrote: One other thing I'd be tempted to look at is that cable and lever setup on the end of the motor. I'm guessing that it is the mechanism that releases the brake when you go into freewheel mode... I'd make sure it releases the brake fully when you go into freewheel, but be loose when in normal driving mode.
Burgerman wrote:That sound can be many things...
Remove the brake.
That ring of bolts marked with a red stripe of paint.
Now push it or drive it and see if that sound goes away. If it does the brake is the cause. If it doesent the motor is the cause.
Now replace it!
martin007 wrote:
How old is the brake / powerchair?
Users browsing this forum: emilevirus, LROBBINS, tettralytic and 149 guests
