Which tools to bring a 12v back to life? and top up stored
-Hi I have 1 set of MK AGM that was still good but dropped to 2 or 3v each that I would like to revive. I also received 2 used set(unknowed history) of mk Gel that are not as low voltage but was too low for a charger to begin charging apparently. I read Burger 's writing saying that it has to be an operation done one battery at the time.
It is usefull to have at least an extra pair of battery to use for a chair we want to repair (to avoid constant battery transfers)and I hope out of the 3 pairs I will have one that allows to roll around the block .
-If the tool can also maintain or top up(bring to 100pourcent) a disconnected battery detached from a wheelchair every 2 or 3 month to prevent sulfatation, i would like that since I need that too.
-I wish it won't cost an arm and a leg but if there is a tool that would proove usefull for the future scenarios and is not that more expensive I might be interested.
What do I look for in bring back to life tool? Correct me if I am wrong but we want low amps(how many) and user defined voltage since MK batteries 's voltage are not standard. Maybe force- repair feature or stuff like that?
I guess if the tool can AUTO Stop when it has to, or be forgotten a bit it would be usefull to know to help me choose since memory can forget to do a task and if constant baby-sitting can be reduced if feels better. but I'm open.
-So noco charger would not be a good choice.
-Would ip65 12 v be a good choice ? it seems to come in 1.1amp 5 amp(low curent mode of 2 an 4amps) 7amp 10 amp with low current option that is unclearly defined...They say it can revive dead batteries but I have not found the how it does it.
-would a power supply do both revive and top-up tasks ? would it be a better futur proof machine?
I read that some member like zxd2400 and een? if they are good solution which versions, models should I look into ?
I have ip65 24V13amp but the voltage only goes down to 26.5v
