Settings for charger or BMS on lithium
For use and in charging.
For e.g in programming, you can set a LOW VOLTAGE CUT OUT in VR2, R-NET for e.g. So you can choose 2 parameters:
a) LOW VOLTAGE setting allows 16V to 22V. Setting to 22V means the last red LED will start rapid flashing and the chair stops when it sees 22V (or 2.7V per cell) on your lithium battery. This is around 98 percent discharged). I do not use this and mines set to 16V as I want to decide when it stops! I would rather destroy a battery and make it home. But if you want to protect the battery it will certainly help. And cut in a fraction before a GOOD QUALITY and BALANCED battery drops below the permanant damage point.
b) LOW VOLTAGE TIME. Determines how long the chair can see this voltage before it stops. So under load it can temporarily go below this figure as you climb a threshold for e.g. So set that to say 10 or 15 seconds. (1 to 255s allowed).
