im going to replace my balance cable connectors from 3 mt30 connectors to a single DB9 connector. while keeping the main charging cables separate using a SB50 connector.
Burgerman wrote:im going to replace my balance cable connectors from 3 mt30 connectors to a single DB9 connector. while keeping the main charging cables separate using a SB50 connector.
If going to the trouble of doing that why not use a single connector for charge and balance as I do?
This lets me make lots of jokes about my 'cordless' drill that runs off my chair....
Burgerman wrote:Which last longer? Probably anderson. But they only have 2 contacts. You would need lots! You should fit anderson too.
I have one or two on everything. Drills, aboyt 10 chargers inputs and outputs, vehicles, chairs, my bed, inverters, solar system panels and connections and outputs in my room, lots of things like car polishers, etc. Even on my RC stuff like the goggles I use on FPV planes and quadcopters. And on my patient hoist. That thing always has a partly dead battery. It frequently refuses to lift me even if full as the batts are too high impedance. And it just bleeps. It only does about 3 lifts per charge even if the batt is new..
ex-Gooserider wrote:I agree, but I find that I like the smaller 15/30/45A powerpole connectors better for most things as they aren't as huge as the SB-50's... My chair that is still on lead bricks, I have the main charge / power wires done w/ PP-75 powerpoles in a compact 2X2 block, w/ a matching jumper block to bridge the two 12V batts to make 24V... I then put a pair of wires to a smaller pair of the PP-connectors across the otherwise empty 24V pins, which I use to connect anything I want to run off 24V...
Burgerman wrote:This lets me make lots of jokes about my 'cordless' drill that runs off my chair....
Ditto... I too have a cordless drill.Now its corded. It runs better off the chair. Or the van. Or the lawnmower. Or the solar system. Or any of my power supplies or reserve battery. Or wherever I happen to need it. And its always "charged".
Hacksaw, black epoxy, soldering iron. Much cheaper than a new battery. When I say everything has an anderson on it I mean it!
Burgerman wrote:No. All cells have a slightly different self discharge rate, and that charge voltage is higher than the full voltage (and there isnt one) So they were all held at 3.55 or 3.60V for at least 15 to 30 mins after balance finished? Then all are 100% full.
Burgerman wrote:Thhe resistance of a cell is lower than that of its connections, cables, and the chargers ability to measure this. Dont let this worry you.
wheelerx wrote: I would very much like to jump to lifepo4 (or other recommendation) and a smaller size. I have a friend !
Users browsing this forum: No registered users and 258 guests
