Is this possible, or do i have to go from a usb port through a converter?
Yet to make up a cable but they bury access to the programming port within the mobility scooter which requires a bit of work to access.
NOPE ...You will NOT be able to program a S45 Solo controller using a SERIAL Port.As it has a real serial port I hoped it would be a fairly simple process.
NO.Is there a problem with the OEM software and Windows 10 I am not aware of?
What cable...make / model... did you use?I double checked my cable build, and everything is correct.
Users browsing this forum: acid_coke, Jay_x, mentado020477, rickystyx, Velcrohead and 58 guests
