Burgerman wrote:you are going to need to make this clearer before I can help.
What are you actually trying to do?
The roboteq for eg, can use many types of input, from voltages (you choose) and frequencies, pulse widths, duty cycles, and can be run like a servo with feedback loop etc.
My problem however is that all the controllers Ive been looking at or had considered ( Kellys minifor a brushless hub or RoboeQ's for a CIMs motor) only seem to allow for one type of pot input rather than two I would need.
I know this possible -or assume it is - because almost all mobility scooters have this setup of a rotary pot and rheostat yet Im having trouble finding any controller that can fit my needs.
Burgerman wrote:All good. But what are you asking?My problem however is that all the controllers Ive been looking at or had considered ( Kellys minifor a brushless hub or RoboeQ's for a CIMs motor) only seem to allow for one type of pot input rather than two I would need.
The controller doesent do this. It still has a voltage swing input.
You need to build your "front end" to do whatever you want your controls to achieve, and then the result of this is fed to the controllers input. So for eg you would have a finger trigger, that gives the full 5v swing for forwards, or reverse, and you would change its range via a divider network which would be your rotary control. This can be total volt swing, or it can reverse it, or it can be eny part of the plus/minus 5v that is the full forward/reverse that controls the vehicle.
The point is that its your input circuit that does this, not the controllers input.
Burgerman wrote:EG when indoors, my roboteq joystick will have a rotary knob so its speed can be reduced to say 2mph max. From 15. This will simply be a reduction of total volt swing due to an additional rotary pot.
Or I may do it on a switch, so it switches in 2 resistors to the ends of the pot when I want to go slow. Or a single one on the output. You can switch on or add via a pot, delay too, by adding a small capacitor that smoothes the joystick or pot output a little when carers or other people are driving it about... This is all simple analog electronics.
woodygb wrote:I'd suggest a complete control system from something like a small mobility scooter.
E.G. The Pride GoGo ..you'd get EVERYTHING you seem to require ...a Wig Wag throttle ( pot ) forward and reverse... together with a Speed limiting pot.
IF you look at the pic ( PGDT S-Drive Controller )it's VERY simple ... on the control side you could actually have just the ON/OFF switch and the 3 pot connections.
woodygb wrote:The main Wig Wag throttle pot has 0v ( pin 8 ) on one end and 5v ( pin 2 ) on the other ...the wiper ...when centered ... will have a value of 2.5v ...so the volts swing/range is 0 to 5v with 2.5v being neutral/off and any value above or below this will be a forward or reverse speed.
The speed pot is inserted into the wiper feed from the main Wig Wag throttle pot ... this reduces the max and min voltage values supplied to the controller and thus max and min speed.
woodygb wrote:Nope ...just leave everything EXACTLY as it is.
woodygb wrote:I've shown a controller that is suitable for a 24v brushed motor .. ANY type of batteries that total 24v upto 28v MAX ... and have sufficient Amp hr's will be fine.
How "fine" depends on the quality etc of the batteries you choose.
Hmmm ..PERHAPS THAT NEEDS QUALIFYING FURTHER.the wig wag pot wiper will give forward and reverse...the speed limit pot can be altered for fast or slow
Is this open cycle when its in powered down state ? ( I noticed it mentioned something about having freewheel speed limit function )
woodygb wrote:Is this open cycle when its in powered down state ? ( I noticed it mentioned something about having freewheel speed limit function )
Sorry Snok ....that statement makes no sense to me,.
snoko wrote:woodygb wrote:I've shown a controller that is suitable for a 24v brushed motor .. ANY type of batteries that total 24v upto 28v MAX ... and have sufficient Amp hr's will be fine.
I also noticed it mentioned something about having freewheel speed limit function which worries me as I was hoping I could use the throttle to coast .
snok
the way that the usual setup works is to have a joystick / wig-wag / twist-grip or other primary control that gives you direct speed control, and almost always has a sort of "deadman" function in that if you don't hold it constantly, if returns to zero. There is then a secondary control knob that sets the RANGE of the main control - essentially it limits your maximum speed, and it may give finer control of intermediate speeds when turned down...
ex-Gooserider wrote:snoko wrote:woodygb wrote:I've shown a controller that is suitable for a 24v brushed motor .. ANY type of batteries that total 24v upto 28v MAX ... and have sufficient Amp hr's will be fine.
snokWhen the typical controller is turned on, it NEVER goes into a "powered down state", and it really doesn't coast - though the power draw goes pretty low at constant speed "cruise" - just enough power to overcome friction and rolling resistance losses. Otherwise, if you are travelling slower than the throttle setting, you will be drawing power trying to accelerate; and if you are travelling faster, the motor will act as a generator, slowing you down and slightly recharging the battery. (This is what you see referred to as "regenerative braking"
The only way to go to a Powered Down state is to shut the controller off entirely, however most will not do open circuit, as the designers of chairs and scooters see power loss as an "emergency condition" and will usually attempt regenerative braking and at the very least, it will allow the mechanical brake (primarily intended to keep you from rolling when stationary) to come on.
Hi GR,
I should of remembered this for myself DUH ( I have been housebound 2 yrs so and not on scooter in about 3-4 ) , as the brake is right at the rear on my scooter it would need an emergency stop , I think ( because I only ever encountered it rolling back on buses ) I must of just assumed this would only work in reverse though ( which would be ok ) but not if I want overunning clutch I can use to coast ( for example down hills or slopes ) or if I needed to propel it myself ( if the battery went flat or I wanted exercise )
I'm not totally sure what you are wanting to do in regards to the speed control, but the way that the usual setup works is to have a joystick / wig-wag / twist-grip or other primary control that gives you direct speed control, and almost always has a sort of "deadman" function in that if you don't hold it constantly, if returns to zero. There is then a secondary control knob that sets the RANGE of the main control - essentially it limits your maximum speed, and it may give finer control of intermediate speeds when turned down...
woodygb wrote:The throttle on mobility scooters is thumb operated , spring loaded and self centering ...this pic shows one ...you simply press the relevant end with your thumb for forward and reverse.
The speed limit pot is used to set a maximum speed range for the throttle.... note that this one has just 2 wires going to the wiper and one track end.
I assume that you would call this option 3?
Users browsing this forum: wheelchairer and 44 guests
