woodygb wrote:The SOLO controller requires the Industrial Software.
woodygb wrote:The pic below shows the connections using an FTDI cable , with the addition of a resistor and Schottky diode ...
BUT a direct connection ( TX of USB to RX of controller ) and ( RX of controller to TX of USB ) plus GND will probably work.
bhuja wrote:woodygb wrote:The pic below shows the connections using an FTDI cable , with the addition of a resistor and Schottky diode ...
Just making sure I am not interpreting this incorrectly, so where the charger usually plugs in to the controller can also be used to program the controller?
mrgus2u wrote:I am also looking for the PG drives oem software for my S-50 controller. I have the dealer software, but it doesn't give me access to many parameters.
...Are you sure that the S-Drive controller is water damaged?Im planning on replacing a water damaged sdrive 120amp controller for my scooter
Users browsing this forum: Bing [Bot] and 83 guests
