The photo's show the diode being soldered on the internal board ...this entails "popping" open the USB case which can usually be done by gently squeezing it in a vice.
IF you can identify the RX and TX wires then you may want to put the diode in the XLR plug.
The photo's show the diode being soldered on the board ...this entails "popping" open the USB case which can usually be done by gently squeezing it in a vice.
thank you loads that just what I needed paddy's micro a duster is a very handy tool in carful hands, as is a Dremill hand them to an ape though and you get next to useless
