Permobil C300 will not move
Hi guys having a bit of a issue diagnosing the problem with a chair not moving. Chair is a Permobil C300 with the Pilot+ control system.
The chair batteries are good and charged, disengage bar is in to engage motors, disengage switch has been checked with continuity to open and close, power button comes on on joystick control, no errors are present, unit is not locked, mode button works and can select mode, all power seat functions work, but the chair will not move in any direction.
I know that the seat has lockouts which can cause this but have not been able to pinpoint a particular switch that is bad.
Seat works as follows:
The tilt backwards will not operate unless the seat elevator is in the full Down position.
Seat Elevator will not raise up if the seat is tilted backwards.
once seat is tilted full forward, seat elevator will go full up and full down.
Back recline and leg extension will work at any point full in and out.
My thoughts are that the problem resides in either the Controller (80 Amp) or the Joystick control. All buttons work on joystick and if mode is selected, moving the stick left, right, up, or down will select a mode or confirm the mode set.
Is there any method to test the joystick or controller ?
Is there a way to bypass all lockout switches to test the joystick and controller ?
Any help would be appreciated.
Thank you,
Richie
Thank you,
Richie
