Also understand that there are TWO different CJSM2 joysticks. One has BT built in and both have infra red control. Both look the same. The BT version is more expensive. I have 4 in total. Two spares in a box, and two on chairs. Only one has BT.
You can also get BT modules that plug into a bus cable. And you can have two if you want. But again not cheap and an add on option. So unless you specified a BT joystick, or a BT module then you likely dont have BT. You DO definitely have IR or infra red though on all CJSM2. That can control any infra red device like light switches, TVs, set top boxes, etc.
Ok, I see. But, my order form said CJSM2-BT, so it has IR etc., built in, right?
Yes that has both BT and IR.
