BM, the way PL8Remote installs and runs is exactly the same as the original PL8 software, no more no less. If you find a difference between them, please let me know.
Both PL8Remote and PL8 software are
ClickOnce apps. ClickOnce is a Microsoft's tech to help developers and software companies to deploy, update and maintain their products easily with low cost. Developers only need to focus to resolve the problems inside the softwares. ClickOnce is very old (born since 2005) and exposed defects. Microsoft developed other teches to replace it like Silverlight, UWP (Windows Store), Blazor. But ClickOnce still has its own values that can not be replaced. So Microsoft still supports ClickOnce in all their recent products.
A ClickOnce app needs a host (on internet or in a local network) to store its application files (exe, dll and others). It has a light setup.exe that does not contain any application file. During installing, the setup will connect to the host to download necessary files. After installing, all ClickOnce apps are store in a "AppData\Local\Apps\2.0" sub folder. When starting, ClickOnce apps automatically connect to the hosts and prompt the user if there is a newer version. If the user chooses to update the new version, all will be done smoothly by one click.
When you run PL8Remote the first time, you will see a 'scary' blue window that says PL8Remote is a 'risky' app. Those who had experience in installing softwares on windows would know that's a 'fake' warning and would simply ignore it. Others might worry and think that I am doing something bad (e.g spying, stealing your personal data). So I will explain it a bit. Microsoft requires that all ClickOnce apps should be signed. To sign a ClickOnce app, I have to buy a cert (about $100/year). But that blue window will still remain even with signed apps. To bypass it, I have to pay another $200/year (total $300/year). It is a crazy cost and serves for nothing. E.g if I was a bad guy (I am not), I still could buy a cert to sign my spywares. A signed app does not mean safe and vice versa. That's only a mater of buying a signing cert or not.
Back to BM's problem "not seeing volts". It's was a bug and I can see what was causing this bug. You were charging/discharging a 24V lead battery. So all cell volts are zero, only pack volt has a value. Is it right? Actually, I calculate the pack volt by summing all cell volts. So pack volt is zero when charging 24V lead battery (which is wrong).
I do not have any lead battery around to test and reproduce the bug. Is it possible if you help me to do the following steps:
- Charge (or discharge) your 24 lead battery in about 3 minutes through the original PL8 software.
- Post a screenshot of PL8 software (the main window, not the graph).
- Stop charging/discharging and upload the "*.CP8" file.
P/S: if you charge/discharge a lithium pack, it will be fine. You will see all graphs.
