Burgerman wrote:Why not just use the motors and controller you have for now. Use toothed belt to reduce speed to say 3.5 mph as its a fraction faster than walking. Will give more torque than stock.
Then whay you can fit better motors and controller to increase speed without losing the torque you need?
woodygb wrote:http://www.invacare.com/cgi-bin/imhqprd/inv_catalog/partsPHII_home.jsp?s=0&pagePostCount=1&partsHome=searchCategoriesToParts&formNbr=01-220&categoryDropDown=4845~Model+R51LXP+only~4845.pdf&selectedModelID=4845&catalogDropDownBox=01-220&fromPage=searchResults&partNbrOrDescr=1086222&catalogTitle=Nutron%c2%ae+
Seems to be 6 mph with 12.5" dia wheels
http://www.1800wheelchair.com/product/7 ... wheelchair
Go with a 2-1 ...twice the number of sprocket teeth on the NEW big wheel as you have on the motor / gearbox drive shaft.
JoeC wrote:If you have a source of power like a 12 volt (or easier, a 6 volt) battery, it's not hard. Get a piece of tape and stick it on the edge of the hub. Give the motor a low voltage, start a stopwatch, and count how many times the piece of tape spins around in a given time. From there it's just a little math to figure out RPMs at 24 volts. The motor spins twice as fast at twice the voltage, if that wasn't clear.
mnm99 wrote:24v at the motor when tested. I used a volt meter. This was using the controller. Should I go direct.
If you measured the actual motor terminals at the output of the controller, not just the battery, then there's no need
mnm99 wrote:OK just did it again. ( 9 ) turns at direct 12v from battery this time.
JoeC wrote:Something is odd here. 9 turns in 15 seconds is 36 RPM, and if you double that from 12 volts to 24 volts, it would go to 72 RPM. That's how the math works, and it shouldn't be off so much.
Are you sure that the parking brake lever was disengaged when you did the direct connection? If it was dragging that could account for the difference.
It doesn't matter if the tape goes on the wheel or the shaft, it will go around the same turns per minute either way.
mnm99 wrote:OK voltage was taken at the batt connector. I used a 16ga wire 1 foot long for the test. I connected 1 foot of 8ga and now get 11 turns.
OK....Last try. I tied both batt together with a 8 ga wire. 24 volts it turned 24x...
