Re: polishing the turd!
Posted: 29 Jan 2020, 20:21
hi bm i been having an issue getting the wizard prog up and running, well that bit the first download went ok,
the 2nd bit the add on or whatever you call it did not run like the first but goes to a screen that says something about drive c and converting?
READ the instructions carefully. You do not "run" it. You overwrite the original non hacked install directory with the new contents. Then you start the program via a shortcut configured to start it. Preferably as ADMINISTRATOR and if it doesent run correctly, also as WinXP service pack 3.
idk what it meant but tried connecting and it does get comms active and i can read the settings currently on there but i cannot alter anything so guess the 2nd download bit has to work at same time but idk how to do that?
Read instructions in the README file...
on another problem i have looked through my collection of wiring harness bit and found the right cables and ends for the 2 motors and brakes to connect to the brain
Do we mean POWER MODULE?
my only problem is finding the correct connector for the main power lead to brain?
Do me mean the battery to power module connector? Get one from any invacare chair, or make up one with a new connector via dynamic.
is there a common cable type as it dont look like a standard enclosed lucar type and i would like to get it right first time,also should the brain be bolted to a heatsink?
It is a power module, and it may help, not essential for normal use. In sport use a fan is usually added.
the original vr2 bolts to a ali heatsink but the new brain is to big for that can i do away with heatsink if its in good vented space?cheers for any helps,peace
Do we mean power module? Yes it will be OK. But heat sink will help if you run into power rollback situations in heavy use.
