Please express in form of top of the fender and chord length , instead of the base line and angle .
Also , I recommend it to cover the entire tyre width.
Working on a modified drawing, should have it soon...
I emphatically do NOT want the fender to cover the entire tire width! I am often needing to get into tight spaces or nerf things out of the way with the chair, and this means scraping and rubbing - If the contact point is the tire, I am unlikely to damage the tire or the thing I'm contacting... If the contact is the fender it will be damaged.... Therefore I want the fender to only cover as much of the tire as is necessary to keep the crap (or at least most of it) off the me and the chair....
