Maxtor wrote:The settings have made him a little calmer.
I still have to get used to it a little.
Can someone tell me how I get into on board programming?
Controls / Global / OBP Keycode ENTRY is set to Yes
Maxtor wrote:Terry, could you tell me your settings?
kajapa wrote:I've had the same problem, but I managed to change the servo settings responsible for the steering control.
If anyone is looking for help with optimus 2 settings then I will help. I have the R-net Meyra oem program.
rickystyx wrote:That's what I'm using so why don't I see this section at all? Is there some way sections can be hidden?
This holds the secret to why I get slowed down as soon as I start a turn - I've never been able to sort that and also why it takes so long for the steering to recover
rickystyx wrote:Terry do you get the servo section on your R-net program - maybe it is just me - don't understand it
rickystyx wrote:Well thank you Łukasz for the file - I now get a servo section but only in a limited format.
On starting R-net I get the following warning - BM is there a way of updating data files from the version I already have?
steves1977uk wrote:It all depends if those Servo settings are in the PM already, if not then the programming software can't see what isn't there. But you can add them from another OEM file that has them.
steves1977uk wrote:As I said above, those Servo settings have to exist in the PM so the software can read them. If no Servo settings exists then the software won't see them. Kajapa have those additional Servo settings in his PM, hence the Sunrise software displays them.
terry2 wrote:So the OEM software does not read everything then?
My OEM software\dongle does not see the servo when reading from the chair.
Great info. Thank you
Re: Meyra Optimus 2 15km/h direkt/drive
Postby Burgerman » Today, 05:38
You may need to grab the original file via the Meyra DEALER software. Then edit it with the OEM one. AFTER RE-SAVING.
Users browsing this forum: DrewDigital, Yennek and 42 guests
