Burgerman wrote:This is all on off meyra scooter software and special programming software for the single channel version of the normal r-net power module. So none of it makes much sense to me or likely anyone else apart from myra.
I've made good progress with the adjustment of my Optimus2 and so far I'm happy with it. At next, I'd like to improve the unstable rear.
Is there an Optimus rider, who has experience with that tail breakout and servo adjustments? Or does anyone have any idea where I could start? (see Picture)
Its not as unstable as rear casters, but its still rear steered. You are attempting to defeat physics. Its not actually possible.
Its not as unstable as rear casters, but its still rear steered. You are attempting to defeat physics. Its not actually possible. Myra did as much of this as they were able already. Its the same problem that all rear steered or rear caster vehicles have.
The obvious real solution would be to turn the seat the opposite way, and run the thing as a rear drive front steered device and disable all stability/front drive/gyro etc so it steers in an accurate stable way that inproves as speed increases. Instead of the opposite.
rickystyx wrote: You can't get into all of the control parmeters or at least I haven't found the right one for taking off the speed reduction for the steering which annoys me occassionally since the speed drops as soon as you are not going perfectly straight (obviously to reduce or compensate for the instability of the front wheel drive) but it is set to reduce the speed as soon as the joystick is moved rather than allowing a 5 or 10% movement before the speed reduction cuts in. I'd be very happy if I could solve that one.
I love my Optimus. Once the warranty expires I'll have serious thoughts about converting to a scooter.
Burgerman wrote: What happes if you set all 3 advanced gate shaping settings to 100.
Burgerman wrote:But it is a scooter.
Burgerman wrote:In an attempt to fix this the rear steer you need super fast servo response an super fast and more accurate gyro response. Those things are out of your hands.
Users browsing this forum: Bing [Bot] and 32 guests
