Need Permolock C3 button / wiring diagram
Postby xtal_01 » 25 Feb 2024, 05:47
My wife has a van with a Permolock C3 ... discontinued years ago.
Does anyone have a wiring diagram and/or parts supplier for a Permolock C3 (Permobil floor lock).
Then you press the button it no longer opens the lock (should release in 3 - 5 seconds). If you hold it for 10 seconds, it opens on "reset" (you do this if the chair does not lock in correctly and gets stuck in the mount) ... so I know the motor works ... and the green light comes on with you lock in so I know the limit switches are working ... just won't release when you press the button (just fyi, the green light goes off after a few seconds when the van is shut off ... it use to say on till you released)
The push button part number is: Art. no. 1824735
I am sure the "standard" button will also work New - 311364 Old - 311364-00-0
I am hoping to either find a button or to find a wiring diagram so I can try repairing the one I have.
Any advice would be appreciated.
xtal_01
Re: Need Permolock C3 button / wiring diagram
Postby slomobile » 03 Feb 2025, 17:08
https://www.manualslib.com/manual/12313 ... ck-C3.html
Maybe not what you were looking for.
If you ever plan to change out the Permolock system for something else, I'll probably buy it from you.
You said " (just fyi, the green light goes off after a few seconds when the van is shut off ... it use to say on till you released)" I don't know much about these, but that seems to indicate that some battery or capacitor has failed or is failing, or that a switched power circuit is intact but a constant battery circuit is broken.
slomobile
