Ricon Lift
Ricon Lift
Postby geordie graham » 04 Dec 2013, 15:23
I have a Ricon lift fitted to my Merc Sprinter van which was working perfect until last week when the hand held wireless controllers stopped working,both of them.The lift still works using the wired in controller.It`s as if the controllers and lift have lost their wireless connection.Any body have any ideas.
Graham
geordie graham
Re: Ricon Lift
Postby Burgerman » 04 Dec 2013, 21:25
Other than the obvious fuses and resetting things, not really. Wherever the receiver is, it may have died.
Re: Ricon Lift
Postby geordie graham » 05 Dec 2013, 16:45
Looks like a trip to an auto electricians.
geordie graham
Re: Ricon Lift
Postby ex-Gooserider » 20 Dec 2013, 04:32
Second the check for fuses and connections - presumably there is some sort of module that recieves the remote signals and sends them to the lift, make sure that module is getting power, and verify it's connections to the lift - seems like where the problem would need to be...
The other 'dummy check' question - which is somewhat unlikely given that both remotes are failing is whether you have a problem with the batteries in the remotes...
Users browsing this forum: No registered users and 21 guests
