Burgerman wrote:Why cant you just set a profile with a max speed that is very slow? Theres no way to push it down a slope faster than its programmed. So it will decend slowly. That way you can do it.
And you drive vast distances!! Even more amazing.
You need a girlfreind thats a gamer, joystick expert!
Not that it helps you much, but here in the UK you would be able to get a carer that takes over from your dad, and probably a get a van too. That you can drive yourself or your carer could. So you would be able to get about easily. And your dad could relax.
Adverse Effects wrote:i can think of a way to make a ramp for a van/high top car that is cable driven and would make the useage very easy to use as long as the car hight is a bit more than the chair is long
