Hello from Tampa Florida USA as well as Hyperion help
Postby iWheel » 17 Dec 2017, 02:36
Happy Holidays !
Question :
I Just purchased the HYPERION 720i net3 AD. Will someone please advise for battery UB12550? everything i Google reads like a gel but is actually SEALED LEAD ACID
Ive tried with the setting at :
1. Li-ion
2. LEAD
Step by Step to setup in memory position 1 would be greatly appreciated
iWheel
Re: Hello from Tampa Florida USA as well as Hyperion help
Postby Burgerman » 17 Dec 2017, 03:33
Thats an AGM battery. Thats lead acid, sealed, deep cycle, recombinent, lead acid, it isnt gel.
Make sure you have the latest firmware, it matters!!! And that charger doesent really have the power for a 50Ah battery. It will work, but slowly.
Set: correct cell count. 6 for 12V or 12 for 24V
Amps MAX
CV volts 14.70
Float volts to 13.6
Set all timers or capacity limits to off/continue/etc.
Those are cheap nasty batteries however and wont last well. After it says done, leave on charge as long as possible, as its actually still charging and will prolong life...
Postby iWheel » 17 Dec 2017, 04:41
Thank you, i Will give this a try next time i have assistance.
You stated these batteries aren't the greatest, do you recommend any?
Chair - Quantum Q6 edge
iWheel
Postby Burgerman » 17 Dec 2017, 11:19
The problem is that many people seem to be having range issues with that chair. It uses grp 22nf batteries which are only 50Ah instead of 70 to 75 for "full sized" grp 24 batteries. So they offer less range, and are worked harder so age fast...
The best batteries wont give a huge improvement but you should be fitting 22nf MK gel batteries, and charging to 14.1V CV and 13.6 float, and for 16 hours each time for good cycle life. But you will need a bigger more powerful charger or you will need 24 hours.
That AD hyperion only has 90w of power! About 3.5A charge. You need 8 to 12A to allow enough time to complete the charge.
Return to Introduce Yourself!
Users browsing this forum: No registered users and 120 guests
