by Burgerman » 18 Jul 2025, 18:54
My views.
Tested several different front drives, a couple more of centre drives, and many rear drives.
ALL my chairs are rear drive.
1. Front drive. Is an unstable platform. The rear keeps on trying to overtake the front, and it really wants to try and go the oposite way. So at anything faster than a crawl, or when turning, these need an electronic gyro. That means that the control system takes priority over your commands. So if you try and program a chair to actually steer in a linear fashion so it turns by how much and when YOU tell it the system doesent always allow it. So the faster you go the worse they steer. That rules them out for me completely. Ant theres a huge chunk of heavy chair and 2 casters swinging around behind you taking out your furniture, and people toes in the pub. So again not for me.
2. Mid drives dont generally have a good ride as the front and rear arms are sprung into the ground to keep you upright on the centre wheels. Thats not suspention at all it just looks like it. ou sit on the drive wheels. So while the odd one has a tiny bit of suspension, most dont. And there are 4 small hard caster wheels rattling you about too. So also not for me. They are not unstable, but not stable. So no gyro needed. But they still tend to be less accurate at speed. The supposed better indoor maneoverability is debatable. They can have small benefits. But if things are tight enough for this to matter you really need to adapt your home or move. Unless you plan of getting better! Some do.
3. Rear drives. ALL stock rear drives are nose heavy. They sit you too far forwards over the saster wheels making them sluggish to steer, not enough traction of rear drive wheels, and they then usually have the stupid wide swing away foot rigging sticking out ahead of the caster wheels. making the chir unwieldy and long indoors. But it doesent need to be that way. They are directionally stable. Meaning that if something like terrain or in fact you change direction at speed, they naturally correct themslves. They offer the best outdoor ride, have nothing sticking out if correctly designed.
So my choice is:
Rear drive. Seat relocated rearwards. Centre smaller footplate to allow that and this shortens the chair and puts the majority of weight on the rear drive wheels. And shortens the whole chair.
Then you get the best of all. Great indoors, best outdoor, light easy stable performance, can take proper programming that gives linear accurate steering and the best smoothest ride.
Take a look at any f my chairs to see this.
