Laptop Suggestion ?
Re: Laptop Suggestion ?
Postby expresso » 06 Apr 2017, 04:27
yes it is night and day -- what took me so long and i like the size also -- so its a plus so far - i just have to figure out settings - etc, and windows - i usually do it as i go along and run into something and then try to figure it out
like windows photo viewer - i remember getting it before but forgot how i did it -
Postby steves1977uk » 06 Apr 2017, 14:49
http://winaero.com/comment.php?comment.news.1836
You can enable Windows Photo Viewer with this, plus tweak many other settings to your liking.
Postby expresso » 06 Apr 2017, 15:25
thanks steve - i am sure i will run into many little things i want to adjust and remove etc, - what i dont like to see is when those messages side out from the side of the screen - usually on the right hand lower side -
Postby steves1977uk » 06 Apr 2017, 15:42
Yep those things are annoying! I disable quite a lot of stuff that isn't wanted on a desktop OS. Why Microsoft thought mixing a mobile (cell) OS into a desktop OS was a good idea is beyond me! If MS made a Windows 7 version of 10 then a lot more people would like it! I have made a custom install.wim without Modern Apps, Defender, etc... so they don't have a chance to install.
Postby Burgerman » 06 Apr 2017, 18:44
I just took them out. Every big update puts them back. They want them there. Thats Microsoft's latest moneymaker. They want to target ads, store, other crap. All gone from mine. The only "ap" I have is the calc. And I might remove it too as the old one is better.
Postby expresso » 06 Apr 2017, 19:03
Burgerman wrote:I just took them out. Every big update puts them back. They want them there. Thats Microsoft's latest moneymaker. They want to target ads, store, other crap. All gone from mine. The only "ap" I have is the calc. And I might remove it too as the old one is better.
would you have happen to have a ISO imagine of Win 10 64 bit your way - ? maybe i can make a ISO disk copy - one day install a fresh copy with one of yours with all the crap removed ?
Postby steves1977uk » 06 Apr 2017, 20:10
I've never had an update that put the CrapApps back in... Are you removing them after installation? The way I do it is I remove them from the Install.wim file in the ISO, that way they can't be put back because they don't exist to begin with. I use this... viewtopic.php?p=99891#p99891
Postby Burgerman » 06 Apr 2017, 20:16
Yes, from memory it wasnt an update that did that although those often leave garbage running like "restore" or change default settings.
I had a windows registry error, and a windows sxs folder error. So ran the filecheck command. It did it...
Postby steves1977uk » 06 Apr 2017, 20:55
Windows 10 Version 1703 (aka Creators Update)...
Code: Select all
https://mdl-tb.ct8.pl/getDirect.php?fileName=Win10_1703_EnglishInternational_x32.iso
https://mdl-tb.ct8.pl/getDirect.php?fileName=Win10_1703_EnglishInternational_x64.iso
https://mdl-tb.ct8.pl/getDirect.php?fileName=Win10_1703_English_x32.iso
https://mdl-tb.ct8.pl/getDirect.php?fileName=Win10_1703_English_x64.iso
English is US English and English International is the Queen's English.
Postby expresso » 06 Apr 2017, 21:18
thanks steve - so now with that ISO - i can just install it as normal and thats it - -
thats great - depends how feed up i get - i may do that to my laptop one day - - with my desktop - its much better - dont have the same setup i guess - never crossed my mind with the desktop
good to have -
Postby steves1977uk » 06 Apr 2017, 21:43
These are normal ISO's expresso :) So you get the complete install like you normally do. You can slim them down by using various tools.
Postby expresso » 06 Apr 2017, 23:25
oh ok - i got excited for a moment - so this is not already slimmed down -- thats what i though -
ok better than nothing - thanks :)
tell me - i have this USB C slot - what can i do with this now - ? i feel limited with the USB ports i have - i have a hub - but would like to keep nothing sticking out of the ports - i move the laptop around -
i am looking at getting a 128 or 256 gig SD card to use as a second storage - since i never really use the SD slot - might as well use it this way -
just that its slow to transfer stuff - but for small stuff its fine -
are they any usb flash drives small mini versions that i can leave connected to the USB C port for extra storage ?
one usb i need for the PL 8 - and the other can be for programming the chair or a usb flash drive - then thats it - i only have two usb port and one usb C port
Postby Gnomatic » 07 Apr 2017, 16:41
U just need a cheap adapter to use the C port as a regular USB port.
https://www.amazon.com/AUKEY-USB-C-Adap ... X2M3864MDS
USB-C is the future of USB. Much faster data transfer rates, more power, and you never need to fiddle with getting it oriented correctly to plug in. There is no right side up. Up, down does not matter with C ports.
https://www.youtube.com/watch?v=ZrZISyPucMg
Postby steves1977uk » 07 Apr 2017, 17:02
Or even this...
https://www.amazon.com/Type-C-Hapurs-Po ... sb+3.1+hub
3 USB 3.0 Type A ports plus a few card reader slots. Also have you looked at USB Thumb drives expresso? Something like this... https://www.amazon.com/Lexar-JumpDrive- ... humb+drive
Postby expresso » 07 Apr 2017, 17:46
yes i have so many thumb drives here - in all sizes - most are now useful because of size - cant hold anything - i keep them around for minor things - but 8 gig - 16 and even 32 gig are useless -
at min. i would get 128gig now and or 256 gig - in trying to keep it slim profile for the laptop - but the larger ones do work faster and stay cooler - so its a comprise i guess -
i like that usb c hub - i may get that in the future -
looking at these also - interesting
https://smile.amazon.com/dp/B01GQPXB3U/ ... J978&psc=1
https://smile.amazon.com/dp/B00SNLH5RE/ ... 986C&psc=1
Postby expresso » 07 Apr 2017, 18:35
i ordered the Hub - i think that would be good - i can make sure of the C port at least and will get one of those 256 mb thumb drive - the fast one -
i returned the SSD i had - no use for it now - i kept the cable for the Sata to usb - and can use it on the HD from old laptop - its slow but can do a back up on it maybe - some storage 500 gig - why throw it out - i figure i put it to some use along with the DVD rom - once i get that cable - will test if it works -
Postby steves1977uk » 08 Apr 2017, 19:15
Just found this... https://sourceforge.net/projects/windows-10-lite/
You run the cmd file during the setup process, and it will strip out the Modern Apps plus you get the chance to create the Administrator account from the beginning without having to create a normal one and then having to unhide it. I haven't tried this yet, so I don't know if it works or not, but can't see why it shouldn't work! :mrgreen:
Postby Burgerman » 08 Apr 2017, 20:52
But I cant do a reinstall, fresh install, because it them takes a month to straighten and customize and fine tune...
Postby expresso » 13 Apr 2017, 00:10
i purchased the USB C hub - one of my thumb drives dosnt work well on it - its a Pariot 3.0 usb 128 gig when i use it - it really has a hard time to read it - locks it up etc,
same drive works fine on the laptop usb port - i got the Hub to use the C port - and give me extra usb port - not sure how good it is though -
i was thinking of getting the new thumb drive 256 gig at blazing 400MB transfer - to use with this hub - hoping it will work or else its useless the hub - for fast speeds
Postby Burgerman » 13 Apr 2017, 10:09
Those USBC hubs require excellent well developed firmware, on both laptop and on the hub as well as the laptop bios. And drivers. Or there will be issues...
Got the dell business 7370 infinity edge glass screen etc with USBC and dell hub, works flawlessly and super fast on my sandisk 128 drive at 130mb per sec continuous. And on my 1gb mechanical SATA/USB external at full speed.
Keep one also in both PC and laptop, on USB3 as they are tiny, bootable from that fancy boot disk by the russian guy, with a complete backup file of drive C made with macrium reflect backup software. So both are bootable too. And fat 32, single partition, 128gb.
Postby expresso » 13 Apr 2017, 15:18
i have the scan disk also - and that works fine - it goes get HOT - thats for sure - but it works - it may be picky with the brand -
i am looking to get this one - now i am worried because of the brand - https://smile.amazon.com/dp/B00SNLH5RE/ ... 986C&psc=1
i cant believe its going to really hit those speeds - - thats faster than most SSD drives - i figure i can leave it on my USB C hub and have an external drive for system imagines etc, - or what ever -
but being Patriot - thats the brand that is not working right on the usb C hub - it works fine on the USB 3.0 port on laptop -
i dont mind scan disk but i figure why not get the fastest
Postby expresso » 13 Apr 2017, 15:33
http://www.dell.com/en-us/shop/4-port-b ... ccessories
is this the one you have BM ? i never though of checking the Dell site for the hub - i forgot i even got a Dell :) maybe this would work better with the Dell laptop - i would like to have those on and off switches for each port - so i can just turn on the ones i want to use - but hard to find those that actually work well --
the ones that work all the time - are the 2.0 models - never had issues with them - once going to 3.0 and now USB C - gets more flaky
Postby Burgerman » 14 Apr 2017, 08:58
http://www.dell.com/en-us/shop/dell-ada ... ccessories designed for Inspiron 13 7368 2-in-1, 15 7569 2-in-1, 17 7778 2-in-1; Latitude 7370; XPS 12 (9250)
http://www.dell.com/en-us/shop/accessor ... 2_recs_ttl Or really go mad. Not sure if your bios supports these or not.
Postby expresso » 14 Apr 2017, 15:28
dont think i have Thunder bolt port - just 3.0 - 2.0 and USB C -
i am going to return the hub i have now - and get the Dell model hub - found on amazon for $34 dollars - will try that one - it also has 2 extra usb C ports - it didnt get great reviews but i see for myself -
what do you think of those Pariot superfast thumb drives i linked too ?
Postby Burgerman » 14 Apr 2017, 17:32
Dunno...
Thunderbolt 3
USB Type-C plug
USB Type-C on a MacBook
Thunderbolt 3 was developed by Intel[46] and uses USB Type-C connectors.[47][48][49] Compared to Thunderbolt 2, Intel's Thunderbolt 3 controller (codenamed Alpine Ridge) doubles the bandwidth to 40 Gbit/s (5 GB/s), halves power consumption, and simultaneously drives two external 4K displays at 60 Hz (or a single external 4K display at 120 Hz, or a 5K display at 60 Hz when using Apple's implementation for the late 2016 MacBook Pros) instead of just the single display previous controllers can drive. The new controller supports PCIe 3.0 and other protocols, including HDMI 2.0, and DisplayPort 1.2 (allowing for 4K resolutions at 60 Hz).[50] By virtue of being an Alternate Mode of USB Type-C, Thunderbolt 3 ports implement USB Power Delivery, allowing the ports to source or sink up to 100 watts of power, which allows companies to eliminate the separate power cable from some devices. Thunderbolt 3 allows backwards compatibility with the first two versions by the use of adapters or transitional cables.[51][52][53]
Intel offers three versions of the controller:[54]
one "DP" (Double Port) version that uses a PCIe 3.0 ×4 link to provide two Thunderbolt 3 ports (DSL6540)
one "SP" (Single Port) version that uses a PCIe 3.0 ×4 link to provide one Thunderbolt 3 port (DSL6340)
an "LP" (Low Power) version that uses a PCIe 3.0 ×2 link to provide one Thunderbolt 3 port (JHL6240).
This follows previous practice, where higher-end devices such as the second-generation Mac Pro, iMac, Retina MacBook Pro, and Mac Mini use two-port controllers; while lower-end, lower-power devices such as the MacBook Air use the one-port version.
Support was added to Intel's Skylake architecture chipsets, shipping during late 2015 into early 2016.[51][52][53]
Devices with Thunderbolt 3 ports began shipping at the beginning of December 2015, including notebooks running Microsoft Windows (from Acer, Asus, Clevo, HP, Dell, Dell Alienware, Lenovo, MSI, and Sony), as well as motherboards (from Gigabyte Technology), and a 0.5 m Thunderbolt 3 passive USB-C cable (from Lintes Technology).[55]
In October 2016, Apple announced the updated MacBook Pro which features between 2 - 4 Thunderbolt 3 ports, depending on the model.[56]
Postby expresso » 15 Apr 2017, 00:22
i guess i give Dell a call one day just to ask and know what i have - specs show USB C -
Postby steves1977uk » 04 May 2017, 20:40
Here's a version of Win 10 with all the crap removed. This might be useful for some :) English US language... http://www.majorgeeks.com/files/details ... ition.html
Postby expresso » 04 May 2017, 22:22
nice thanks - i will make a copy for myself
Postby expresso » 01 Jul 2017, 00:25
BM - can you believe the luck i am having here now - between the tires and now the new Dell laptop i got - i feel i have to return it for repairs -
its making some noise also - acting strange and dosnt recognize the charger - during boot - it gives me a message about it - problem is i need a laptop and cant be without one now - if this has to go in for service which i think i want to send it to be checked
i have to get another 2nd one for a backup -
not even 6 months old -
https://smile.amazon.com/HP-14-inch-E2- ... l_huc_item
is this any good for a spare backup ?
Postby Burgerman » 01 Jul 2017, 00:30
No idea. You should have got the XPS 13 with glass infinity screen. Best most compact 13 inch laptop on the planet.
http://www.dell.com/uk/p/xps-13-9350-laptop/pd
Return to Anything
Users browsing this forum: No registered users and 45 guests
