Burgerman wrote:Be specific one question at a time. Or I will have to write more than a sentence. And I will try to help. As it is I have no idea what to answer.
That screenshot may be your new instalation, your old instalalation and is Enterprize LTSC 1806. As it says on screen. How it got there and what you used to activate it only you can know. And presumably you kept both software and activator safe. Thats why we all do backups / storage right?
Ok - ok the win 10 i made the boot usb with -
it worked - i installed it - but it was very limited - had almost nothing on the menu - - or should i say start menu - there was almost nothing there -
maybe its hidden -
i installed firefox - i went to search using firefox - and was not able to search - did nothing - not sure why - i did nothing other than install it - i had to install firefox from a usb since there were no browsers with that OS - not a big deal -
after installing firefox - i went to search for some stuff - nothing happened -
besides that - the OS i am using right now is Win 10 LSTC - i have the disk for that one -
i know my new setup wont have any Dvd or CD drives - i do have an external one for those times if i ever needed one -
between the one i am using now - i posted the pic - compared to the one i have on the boot usb to install on new system -whats the difference between them - the start menu for sure is not the same -
will it work the same or would i be so limited if using the new on on the boot usb - not sure what the difference is from this LTSC vs the Pro ? is it just the privacy stuff - which is fine without that - but will it work the same in terms of updating it - or drivers - etc.
OR maybe i got this Win 10 from when i had Win 7 and got the free upgrade
its been a while - i dont remember how i got this Win 10 - i though maybe it was from you with the crack -
i know i have a disk labled Win 10 64 fresh - i dont know which crack was used for this one - if any at all -
i think i got it from you - years ago now - looking at my folder with the Win 10 stuff - i cant say which is what for sure
the only one i know for sure is the current activator you gave me - to go with the boot usb i made -
i have my old office 2016 - i can still use that one- have the activator for that - all i use it for - to type a letter - etc. dosnt have be the latest - but if you have it also - i take it -
BM - that boot usb i made with the Win LTSC
it works - i tried it on my computer - it boots and loads etc, but what is different about it - from the Win 10 Pro ?
i dosnt have any browsers - seems to have nothing at all on the menu bar - or just very different - will take time to learn it - get my shortcuts etc,
what am i missing by using this ? when i installed firefox - i was not able to search - just did nothing -
wondering if i should use it on my new system ? i was under the impression its limited with junk - it seems very limited to the point you cant even search ?
i went back to my old setup - now i know to put all my programs on a usb to install -
Firefox was used to search - not the taskbar - i said that from the start -
its not that i didnt like the new install - it was very different - start menu - etc, - and didnt have nothing compared to what i have on the start menu -
its not a problem if thats how it is - just have to figure out the hidden settings and how to get where i want - like MY PC -
about two days ago - you gave me the link to download the OS and made a boot usb with rufus - thats the one i installed -
its Win 10 LTSC - - either way - the activator works for all of them - ? in that case - its fine -
i dont have a activator for office 2019 - if you do - send it over - a one click version - link to download office 2019 - i see others 365 office etc,
whats the easiest way to clone what i have now ?
when i get my new SSD M2 - can i clone it now - then just install it on my new setup ? or will the hardware give me an issue - since its different ?
Burgerman wrote:If it wont boot be sure you have all the bios setting correct!
If it still wont boot use your USB stick and do a REPAIR not an install. Then it will....
Then go to the DEVICE MANAGER. Choose SHOW HIDDEN DEVICES.
Then choose to DELETE everything it shows that is greyed out. These are the old drivers for your old motherboard and other devices no longer present. There may be lots!
Then add all the missing drivers initially from the disk that comes with your board. Then remove any SOFTWARE that was motherboard specific. For e.g gigabyte stuff if you now have a ASUS or whatever. And then you are done.
how do i use the disk that comes with the board with no disk drives
steves1977uk wrote:Why not get a 128GB+ SSD and use it with SATA-USB3 cable, make it bootable from the LTSC ISO. Then copy drivers/office 2019 and others to it, now you will have everything on SSD ready to install.
expresso wrote:i dont get how i can burn many iso or others at once on one bootable drive -
when i burn the ISO it formats the drive dosnt it ? what your suggesting is good - i never it done it that way - and dont know what i will need later if i want to add to it
its not a big deal - i can use one of my flash drives - empty it - then burn the ISO - install it and can reuse the usb after installed
with a rescue disk - usb - dont i need to have just that one item on the drive - in case to recover from - macurium etc,
Users browsing this forum: No registered users and 102 guests
