hasnt hit past 84C - at max load with handbrake - using OCCT stress - its cooler than using handbrake
idle seems a bit high but who knows - with Ryzen and built in graphics may be norm. the fans CPU is full speed - the rest are silent mode in bios -
case air is not hot feeling the rear fan air - i am using a hub - i like a nice fan software i can adjust in windows - without going in the bios -
cant seem to find one that works - i wonder is it because of the hub i am using - i know the hub works from one pin - the rest of the fans will adjust according to that one pin -
ALWAYS choose manual, advanced, in every case in everything!in the bios with the fans - i can use silent - normal - full - using Volts PWM - Auto - or manual - i found the manual didnt ramp up as i set them - maybe
because of the hub ?
expresso wrote:case air is not hot feeling the rear fan air - i am using a hub - i like a nice fan software i can adjust in windows - without going in the bios -
in the bios with the fans - i can use silent - normal - full - using Volts PWM - Auto - or manual - i found the manual didnt ramp up as i set them - maybe because of the hub ?
left them on Auto - silent mode - works fine - actually even on full speed - didnt change the temps much if any - so that tells me the case fans are fine
cpu cooler and fan - thats whats giving me my temps - so i leave it - or change the paste once just to see - if that does anything different
add the card maybe to play - and or get an 280 Aio - but i try the paste first one day - i hate to touch it - it looks too nice -
I pretty much agree with what Ryzen-Type-r just posted.
It's your decision, but I would not let it alone.
An old engineering adage stated, that for every 10C you can drop the Temp on a Chip you double its life.
I believe you should take a straight forward approach and lower the Thermal-Throttle-Limit for your processor.
Then test its performance. I don't think you will lose much performance. It's those last few MHz that cost a lot in voltage and temps.
Set PBO to Advanced.
Set Limits to Manual
Set Thermal-Throttle-Limit to Manual
Set the new field "Thermal Throttle Limit" to a temperature (in Celsius) that you feel comfortable with. (Me I like 75)
steves1977uk wrote:expresso wrote:case air is not hot feeling the rear fan air - i am using a hub - i like a nice fan software i can adjust in windows - without going in the bios -
Expresso!, you do not NEED any crappy fan control software if you configure the BIOS correctly. My ASUS boards has this built in and I disable it. As I said to you in PM my i9-9900KF is a hot CPU by design and yet it idles at 30C without any fan control software.
This is the reason your CPU sits at 4GHz at idle, because it's having to monitor the fan software which defeats the purpose of a cool and quiet system! And that's why your CPU fan is going full whack because you've set it up incorrectly. An AIO won't solve your CPU temps because you've just added MORE cooling which draws more power. Just stick the Mugen 5 on it and be done!
expresso wrote:fan hub is connected to one fan header on the MB - and 3 fans connected to the hub - 200MM front fan - 140mm rear and top fan -
which would be better to leave it on PWM ? i have to say the 200mm front fan is a 3 pin though - rest are 4 pin
what would you do - if you go outside and nothing is around but homes
Burgerman wrote:Will there be cake?
If so I will be there!
