Burgerman wrote:Does anyone still use spinning rust drives in 2022?
Burgerman wrote:Well I dont know how you could spend more really, everything was best fastest and highest quality available. Unless you paid some incompetant to do it all. But I am an ex plumber! So pipes better be good! My reputation depends on it!
You could have used a 3090 in place of the 3080Ti, wasted another 500 for a literal 2% higher frame rate in some games. But thats about it. But the overclock gains 8% and beats that anyway in frame rates. And the CPU overclock gains a massive 20% in multithreaded stuff. From 3.4ghz stock to 4.8ghz base clock on all core. And from 4.9 to 5.2ghz on single core - sustained because of cooling setup. No throttling even at a 245 watt over boost. Up from the stock 105.
Actual PC build was just a matter of planning with a very capable high power vrm mainboard and the right CPU, and getting the right radiators, fans, distro blocks, pumps etc that will fit neatly, maximise radiator area, and work together in fittings, bends, air vents/drains and its all just planning ahead.
It actually looks way better in reality than the pics. They dont show how good it really is. Colours etc dont show, cleanliness and wiring too. But build one, its fun!
Users browsing this forum: No registered users and 13 guests
