Burgerman wrote:GO BACK and read it FULLY before replying!
Burgerman wrote:Theres nothing in it to "wear out". If it works when it was new, with the stock bios settings it CAME WITH, and the operating system set up as it was when new, then it will work the same today. But you have changed something maybe many things. And thats why its doing strange stuff.
And you did not read my post!
What model is it?
Burgerman wrote:Yes.
Then enter bios after setting defaults, and DISABLE adapter genuine check!
The laptop you are wanting is probably the one you alrady have it just needs properly configuring.
Burgerman wrote:When they fail to run, or the screen is black. Thats how you tell its worn out. They dont degrade. They fail suddenly. Transistors work or they dont. Except for dust in CPU fan. Hit the lots with a vaccuum cleaner. But that just limits max cpu speed.
Burgerman wrote:Dell drivers are frequently crap. And chipset drivers. Those allow jumpy mouse and black screens. Install the drivers that WORK not the latest ones that dell ends automatically... YOU drive the computer.
Then once good drivers stop messing with new ones! Unless you keep track and roll back if they cause issues such as you have. I had a bad chipset or graphics driver from dell that did all of your issues. Nothing wrong with the hardware. It either works or it doesent.
