steves1977uk wrote:Sorted! My Brother managed to assemble the bearing puller the opposite way and it actually pulls the bearing back onto the axle without too much trouble. So I'm pleased!
steves1977uk wrote: but you need to tap the bearings back onto the axle with a but not too hard.
On putting a bearing back , did you apply thrust on its inner ring or the outer ring of it ?
The outer ring only is best. You can use an old bearing and cover the new one and gently tap with hammer and be sure its seated and going in square.
Would it be a good idea to apply a cover of anti-corrosion grease before fitting?
Users browsing this forum: No registered users and 51 guests
