>>> I bought 2 Ping batteries for my Travelscoot. A 20ah and a 10ah.
Why 2 and why different sizes? What voltage are your packs? 12, 24?
>>> I asked Ping about fast charging and he said that the maximum rate should be 5 amps because of the electronic battery monitoring system attached to the batteries.
Lithium batteries are very good at high charge rates as long as the correct 3.6v max cc/cv charge algo is observed (for A123 or LiFePO4). And not a fraction of a volt over that 3.6v per cell. He sells them with a simple circuit that can "sink" or waste any extra energy so as to prevent the cells being over charged. So you can actually feed them more. But too many amps and you will damage the circuit. The real answer is a proper charger for Lithium Batteries, which includes cell balancing such as the ones we model heli people use and dispose of the cheap BMS system.
But 5 amps on a 10 amp hour battery is already 2C which means its fast now. Or 4 hours on the 20 Ah battery?
>>> Has anyone purchased any yet as I would be interested in your findings. I have a TGA Supersport with a range of 32 miles on 100ah batteries and wonder if the LifePO4 would extend that.
I have SERIOUSLY considered it. But to replace two 70 Ah group 24 powerchair batteries means a huge expense and only an increase from 70 to around 100 Ah because LiFePO4 batteries are not very compact. So a big expense for minimal gains although weight is also a benefit as they are about half as heavy. So so far I didnt bother.
LiPo Lithium Iron Polymer offers about 6x better energy density than lead batteries though. Unfortunately it burns rather violently and I cant get off the powerchair! So again not dared do that yet...
You also gain about 20 to 30 percent range because of the peukert effect on capacity as well though. Which almost makes the swap worthwhile.
Unless you mean as an ADD ON to extend range? That works!
http://www.wheelchairdriver.com/extende ... rchair.htm
