P&G VSI 50A
Re: P&G VSI 50A
Postby woodygb » 15 Jun 2021, 18:28
The controller can only be turnt on when the joystick cover is alligned probably with the PCB
.... ODD! I have not come across this problem with any of the various pod types.... BUT ...I have not had a NEW VSi in my possession.
download/file.php?id=15768&mode=view
Your pic seems to show a possible microswitch "tongue" in lime green in the left hand side casting rail.
Re: P&G VSI 50A
Postby nani13 » 16 Jun 2021, 07:06
woodygb wrote:Strange question to ask about the ribbon pitch ...measure yours and tell me what your ribbon pitch is.
The 4 voltages ( 2 off X & 2 off Y ) MUST be 2.5v at start up AND Vs/2 must also be 2.5v.
This might help you ...
This is what we measured with a DMM
Neutral Voltage: 2.5V
Pin 2 Left= 3.8v , Right=1.2v
Pin 7 Left=3.9v , right= 1.1v
Pin 4 Forward= 1.1v , Reverse= 3.9v
Pin 5 Forward = 1.1v, reverse = 3.9v
nani13
Re: P&G VSI 50A
Postby woodygb » 16 Jun 2021, 08:30
Good ... any problems with making an external interface?
Re: P&G VSI 50A
Postby nani13 » 16 Jun 2021, 13:20
woodygb wrote:Good ... any problems with making an external interface?
nope. But I am wondering what is the value of the digital pot?
nani13
Re: P&G VSI 50A
Postby woodygb » 16 Jun 2021, 14:35
You mean Ohms value?
The part number of the Digital pot is written on the schematic that I posted and it equates to only one resistance value.
I will leave you to Google it.
Re: P&G VSI 50A
Postby nani13 » 16 Jun 2021, 15:26
woodygb wrote:You mean Ohms value?
The 4261 consists of 5kohm, 10kohm, 50kohm and 100kohm. I was wondering which value you used in the diagram?
nani13
Re: P&G VSI 50A
Postby woodygb » 16 Jun 2021, 15:46
MCP4261-502E/P, Digital Potentiometer 5kΩ 257-Position Linear 2-Channel Serial-SPI 14 Pin, PDIP
You could have done a bit of resistor network math.
The schematic shows the MCP4261 that is wired as 2 off resistors in parallel , each end is fed by a 1k resistor .
So we have 5v feeding a resistor divider consisting of ....0v > 1k ( 1.3v required at this point ) ?Ohms ( 3.7v required at this point) 1k < 5v ...
solve for ?Ohms....then double it.
https://www.electronics2000.co.uk/assist/assist.exe
Re: P&G VSI 50A
Postby woodygb » 16 Jun 2021, 16:04
You can also see from the schematic that I have bifurcated the outputs of the MCP and fed them to the relevant pins.
Return to Powerchair Reviews
Users browsing this forum: No registered users and 133 guests
