I wonder how many wires he thinks need soldering ?
There will be none. Unless he breaks it. But even then its simple to re-solder it.
Send us a picture!
thanks for all the ideas !! - heres an update - i called tech support and got a nice lady which knew alot - first off - the toggle is soldered on the board and she did not recommend trying to unsolder etc, - other issue can happen if you make a mistake etc, - thats one -
LROBBINS wrote:Try this test. Connect one of your compact chargers, but let it run all night instead of disconnecting when the green light comes on. Now see what the Lester says. That green light is set at 80-90%, which is when the unit should switch to float charge (actually, would be better if it went to 99% first, but that would require having exactly the right voltage for the battery and the mfrs use a "compromise" voltage more-or-less acceptable for all types of Pb batteries). It will continue to slowly charge at the reduced voltage after that, however, and should come up to full charge without the risk of over-charge that one has with the Lester. Ciao, Lenny
Burgerman wrote:Yes, ignore the green ready light. That is NOT the end of charge. Leave as long as you possibly can. A month is not too long. It takes about 10 hours to fully charge a lead battery. The old lester charger though will lie. Because instead of sensing voltage and current, it uses a timer too. So will apear to be charging even if the battery is accepting no charge.
The old heavy charger is an antique. It is really best to dispose of it, even though you think it works "better"... Unless you know EXACTLY what it is doing.
The small 3 stage chargers you had were generic chargers and again they were quite likely to be charging incorrectly, and telling you the battery was charged long before it was.
__________________
YOU MUST match the charge algo to the exact battery you are charging. Theres no such thing as an automatic do all charger.
A gel MK for eg needs any amps (5 to 30 Amp is fine with bigger being faster) and 14.1v (28.2v) CV stage. It should STOP charging when amps fall to around 100 to 500th of C. C is capacity. NOT EARLIER. Than it should sit at 13.6v to 13.7v indefinitely.
An AGM battery needs 5 to 100 amps, at 14.4v (28.8V) CV stage. And should stop at the same 100th to 500th of C. NOT EARLIER. Then sit at 13.5v float forever.
An Odyssey or other pure lead should be charged at thehighest rate preferably, no upper limit. And at 14.7v until 100thC to 1000thC for best cycle life. And a 13.5 float forever.
These things matter. So you MUST know exactly what its doing.
1st link. Finishing voltage: 2.28 volts per cell float; 2.4 volts per
cell finishing.
2nd link - Absorption Voltage 29.2 +/- 0.2 V
3rd link, 24 Volt, 8 Amp auto charger for all lead-acid battery types - GEL/AGM/Wet
i understand everyones point - but it dosnt translate to real life usage to me - if you were me - you would do the same thing - if charger -A- gives you 5 hours of usage - - Charger B gives you 10 -- you would use Charger- B -- just an example -
Users browsing this forum: No registered users and 17 guests
